tommo Posted December 5, 2003 Report Posted December 5, 2003 i have stock pipes and the seals that join the pipes together (the ones under the seat) have rips in each one and i was going to just replace them but they are charging 40 bucks each(aussie dollar) . now my bike sounds awsome but there is a bit of smoke coming out and i am worried that i might be loosing rear compresion from this? is there anything that i could put on the pipes to seal them up?any replies will help lots Quote
boonman Posted December 5, 2003 Report Posted December 5, 2003 You can use I believe it is 3/4" heater hose. Quote
fixitrod Posted December 5, 2003 Report Posted December 5, 2003 I have fattys and I think I used 1" or 1 1/4" heater hose. I had to tighten them the first couple times as the rubber heated and changed properties. They've been on for 2 yrs now and still work fine. Quote
boonman Posted December 5, 2003 Report Posted December 5, 2003 Why in the hell am I thinking of 3/4" hose? Quote
Klotz Posted December 5, 2003 Report Posted December 5, 2003 i just use pipe wrap...and it works fine..lol i think im talking about what you guys are shane Quote
BenBB Posted December 5, 2003 Report Posted December 5, 2003 I used 1-1/8" Hydraulic hose. If you can find something close you can always use some hi-temp RTV on the inside to help it seal and hold up to the exhuast heat a little better. Boonman you must be thinkin' of a different kinda pipe (a hooka?)... Quote
