tommo
Everything posted by tommo
  1. i just got out the old power drill and drilled two new holes a bit closer than the original holes. my plastics are now as good as new and nice and stiff
  2. hey guys, i just bought a new DID xring chain ,14 and 42 size sprockets and sliders and i need to know how many links i need to take out of my chain . my shee has stock everything like swingarm and stuff. any help would be very appreciated as i want to get it running by the weekend. thanks
  3. f*ck yeah!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! oi this shit takes to long after this im gettin off the net and ill just call you ok
  4. ill believe it when youve rooted her . my score is 4 717 000. hey guess what i start my new job on 13 jan so you better come 2 ledge bfore then
  5. yeah keep dreamin..... whats your highest score on pinball?
  6. just face it adam yr bike is fucked!
  7. the locknut in the middle has nothin to do with the tyre and rim it just holds the the wheel mounting thing on the axle
  8. i have stock pipes and the seals that join the pipes together (the ones under the seat) have rips in each one and i was going to just replace them but they are charging 40 bucks each(aussie dollar) . now my bike sounds awsome but there is a bit of smoke coming out and i am worried that i might be loosing rear compresion from this? is there anything that i could put on the pipes to seal them up?any replies will help lots
  9. i say go ahead and buy one ,a shee was my first bike and after you get used to the powerband you can then tame the beast ,for some reason since i was like 12 i wanted one really bad but my parents wouldmt buy me any bike but when i turned sixteen there it was and when its working ,riding is a whole lot of arm slinging action.oh yeah and ninjamaster ,im sorry but warriors are damn slow. i dragged one after a few months of havn my shee and killed it .in fourth i was a good 15-20m in front. my shee shee is my first bike .
  10. hey guys , i was wondering how much a stock 2001 banshee can take when jumping. especially the axle. ive had my bike for a good 8 months and ive mostly been doin burms roostin and hill climbing. i now want to start getting some decent air . do i need to do anything inparticular to prep my bike for this(by this i mean adjust my present parts)and how much can my shee take until it will start to shit itself. i weigh around 70 kg and my bike is pretty much stock standard. any replies will be much appreciated
  11. i had the same problem with pains in my legs and abs the first time i went riding. i couldnt walk for two days because my legs were so strained. but i just kept riding again and again and after a while your body gets stronger and tonesup in those areas . now i can ride all day and then hit the sack and be fine the next day no probs.
  12. just make sure your axle has no slack, i found this out the hard way and ended up with a chunk out of my bottom end missing. i realised the axle was loose because when i climbed up any hill i could feel the bike joulting , it was the chain slipping so i tryed to ride home (about 10 km) but i didnt make it. i had to get my bike towed home with our 4wd . the axle bearings were completly f!#@kd and they were so bad that it even ripped up the side and inside of my casing but likily the shop could machine it down and it is as good as new except for the chunk missing.
  13. whats i side winder ,i live in perth, australia ,can you buy them there? how much are 530s ,can it go on a stock shee
  14. hey guys , i need to get a new chain because my old one is so stretched i cant even tighten it with the adjusters . any way i was just wondering what is the difference between o ring and x ring chains , is the x ring just a fancy rip off or is it actually good and can we evn get x rings for the shees .thanks
  15. my banshee is prettymuch stock with dominators ,no snorkel and all the pointless shit like the plates behind your pegs and the black guards on the back and stuff ripped off. i found that there was alot more shifting to be done with the 13 but it seemed to get the front up in the air alot easier and it did climb hills alot better in fourth . im running the 41 on the back . at the moment ive screwed up my whole chain drive so i need to get new sprockets and chain all new rollers and sliders . all this because my bearings collapsed while i was riding .should i get any different sprocket sizes on front or/and rear if so what size and what effects , or should i just stick with 14/ 41. (sorry a wrote so long,im really bored )
  16. i ride in mostly sand dunes but sometimes trails . i have kenda dominatrs on the rear. from your replies it sounds like i should stick with the 14 . are there any cheap ways to increase bottom end?
  17. hey , my shee is prettymuch stock with 20 inch dominators on the rear and i got a 13 tooth front sprocket instead of the 14, i was just wondering what the good /bad affects of this could be? thanks
  18. cool i think ill try that 2x6 tightening thing, thanks for your replys guys
  19. i want to fit a rev tacho to my bike but just a little one i was just wondering how much the would cost, do i need a special type and how where and how do i connect it ?. i was thinking of pulling one of a 250 2 stroke dirt/ trail bike. how high does a stock shee revvvvvv!
  20. im a bit worried that if i run over my tyres they might split . is there any chance of this happening
  21. hey i want to turn my front tyres inside out for more width on my bike but my valves hit against my brakes . i went out and bought some tubes and i am planning to take my tyres off the rim and position the valve on the other side of the rim. the only problem i am having is that i cant get the damn tyre of the wheel, any reply and help will be much appreciated thanks
