Barnet Dirt Digger carbon fiber clutch kit question
Carbon fiber is a tough friction material. So it's also tough when it's floating around in the oil. I'd prefer a cork friction material clutch plates. Check out a Fast or drive line clutch.
does this mean it will wear out faster? will it last more than OEM? and can i use it with my oem basket?
Barnett used to make the Dirt Digger with Organic material fibers. It used a Kevlar inner and outer fiber to protect the aluminum OEM pressure plates. They worked well for us in our asphalt Banshee's but when they switched to making the DD with all Kevlar disc's we had slippage problems and it "muddied" the oil badly and very quick. I got a big order of organics custom made but it was super expensive (was charged list per plate). Bottom line - You won't go wrong with cork clutches. I've not used Drivelines but the one Jeff (FAST) sells is great.
  • Like 1
