EaCastillo00 Posted May 13, 2016 Report Posted May 13, 2016 One question: how good are barnett clutch kits in general vs OEM? and Is this kit compatible with my stock clutch basket? Barnet Dirt Digger carbon fiber clutch kit Quote
jbooker82 Posted May 13, 2016 Report Posted May 13, 2016 Carbon fiber is a tough friction material. So it's also tough when it's floating around in the oil. I'd prefer a cork friction material clutch plates. Check out a Fast or drive line clutch. Quote
EaCastillo00 Posted May 13, 2016 Author Report Posted May 13, 2016 Carbon fiber is a tough friction material. So it's also tough when it's floating around in the oil. I'd prefer a cork friction material clutch plates. Check out a Fast or drive line clutch. does this mean it will wear out faster? will it last more than OEM? and can i use it with my oem basket? Quote
sheerider11 Posted May 13, 2016 Report Posted May 13, 2016 I'd skip Barnett and get a fast clutch. Quote
EaCastillo00 Posted May 13, 2016 Author Report Posted May 13, 2016 I'd skip Barnett and get a fast clutch. i have looked for them, what is fast? cant seem to find it Quote
sheerider11 Posted May 13, 2016 Report Posted May 13, 2016 i have looked for them, what is fast? cant seem to find itSite sponsor. FAST.Farm and sand toys. Quote
Tedder Posted May 13, 2016 Report Posted May 13, 2016 Barnett used to make the Dirt Digger with Organic material fibers. It used a Kevlar inner and outer fiber to protect the aluminum OEM pressure plates. They worked well for us in our asphalt Banshee's but when they switched to making the DD with all Kevlar disc's we had slippage problems and it "muddied" the oil badly and very quick. I got a big order of organics custom made but it was super expensive (was charged list per plate). Bottom line - You won't go wrong with cork clutches. I've not used Drivelines but the one Jeff (FAST) sells is great. 1 Quote
