Larry's Shee Posted April 23, 2016 Report Posted April 23, 2016 Best "Tool" for DIY is a Clymers Repair Manual. Tells how to leak down test, check head for warp. Not a fan of reusing gaskets, the head is a one use only gasket. 1 Quote
gregckrt1 Posted April 23, 2016 Author Report Posted April 23, 2016 Best "Tool" for DIY is a Clymers Repair Manual. Tells how to leak down test, check head for warp. Not a fan of reusing gaskets, the head is a one use only gasket.I'll have to look into that and I thought it wouldn't be bad bc I only rode it so long and then just took it off to get hoaned Sent from my LG-H900 using Tapatalk Quote
Larry's Shee Posted April 23, 2016 Report Posted April 23, 2016 The head gasket has a ridge that gets flattened when torqued. Second time used, no ridge. That's also why it's marked "UP". Quote
gregckrt1 Posted April 23, 2016 Author Report Posted April 23, 2016 The head gasket has a ridge that gets flattened when torqued. Second time used, no ridge. That's also why it's marked "UP".I didn't reuse the top head gasket I reused the bottoms and they're like some different material not metal Sent from my LG-H900 using Tapatalk Quote
sheerider11 Posted April 23, 2016 Report Posted April 23, 2016 Did uou tq cylinders prior to head? Are they level? Are we even sure it's a coolant leak? Quote
gregckrt1 Posted April 23, 2016 Author Report Posted April 23, 2016 Did uou tq cylinders prior to head? Are they level? Are we even sure it's a coolant leak? I torqued them starting at 10 15 and then 20 and I did like 21-22 bc I had a extension on the ratchet. Everything looks pretty even as far as how far the studs stick out the top the head. And No were not 100% sure about the coolant leak I re used the bottom gaskets(which are like cardboard it felt like?) it doesn't look like it's leaking and I had it started for a couple seconds stall out Then kicked it again boom backfire Sent from my LG-H900 using Tapatalk Quote
sheerider11 Posted April 23, 2016 Report Posted April 23, 2016 I torqued them starting at 10 15 and then 20 and I did like 21-22 bc I had a extension on the ratchet. Everything looks pretty even as far as how far the studs stick out the top the head. And No were not 100% sure about the coolant leak I re used the bottom gaskets(which are like cardboard it felt like?) it doesn't look like it's leaking and I had it started for a couple seconds stall out Then kicked it again boom backfire Sent from my LG-H900 using Tapatalk So how much white smoke? Get us pics of the plugs Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
gregckrt1 Posted April 23, 2016 Author Report Posted April 23, 2016 Ok I will and I'll try to tape the smoke Sent from my LG-H900 using Tapatalk Quote
gregckrt1 Posted April 23, 2016 Author Report Posted April 23, 2016 So how much white smoke? Get us pics of the plugs Sent from my SAMSUNG-SM-G890A using Tapatalk Ok I'll get some pics and I'll try to get a video of the smoke and how it sounds. Might be a dumb question but say I called auto zone and asked for a 2 stroke leak down test and they said they had one but not for 2 strokes. Does it matter or does it matter Sent from my LG-H900 using Tapatalk Quote
sheerider11 Posted April 23, 2016 Report Posted April 23, 2016 Ok I'll get some pics and I'll try to get a video of the smoke and how it sounds. Might be a dumb question but say I called auto zone and asked for a 2 stroke leak down test and they said they had one but not for 2 strokes. Does it matter or does it matter Sent from my LG-H900 using Tapatalk People have made them work. But a trip to autozone and home Depot and you can have your own Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
hoppedupandcutdown Posted April 23, 2016 Report Posted April 23, 2016 Get one for an import car, as long as it fits the radiator neck, it'll work. For the cooling system pressure test. Quote
gregckrt1 Posted April 23, 2016 Author Report Posted April 23, 2016 People have made them work. But a trip to autozone and home Depot and you can have your own Sent from my SAMSUNG-SM-G890A using Tapatalk With the pvc pipe and the air pump? I think I watch a YouTube video on that Sent from my LG-H900 using Tapatalk Quote
sheerider11 Posted April 23, 2016 Report Posted April 23, 2016 With the pvc pipe and the air pump? I think I watch a YouTube video on that Sent from my LG-H900 using Tapatalk Yeah. But still get the coolant pressure tester. It's an easier tester to use Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
gregckrt1 Posted April 23, 2016 Author Report Posted April 23, 2016 Yeah. But still get the coolant pressure tester. It's an easier tester to use Sent from my SAMSUNG-SM-G890A using Tapatalk I'll call auto zone back then n get it Sent from my LG-H900 using Tapatalk Quote
gregckrt1 Posted April 24, 2016 Author Report Posted April 24, 2016 Yeah. But still get the coolant pressure tester. It's an easier tester to use Sent from my SAMSUNG-SM-G890A using Tapatalk This is the left plug it's wet This is the right plug Yeah. But still get the coolant pressure tester. It's an easier tester to use Sent from my SAMSUNG-SM-G890A using Tapatalk Sent from my LG-H900 using Tapatalk Quote
