Banshee rebuild problems
Best "Tool" for DIY is a Clymers Repair Manual. Tells how to leak down test, check head for warp. Not a fan of reusing gaskets, the head is a one use only gasket.
I'll have to look into that and I thought it wouldn't be bad bc I only rode it so long and then just took it off to get hoaned
Sent from my LG-H900 using Tapatalk
Did uou tq cylinders prior to head?
Are they level?
Are we even sure it's a coolant leak?
I torqued them starting at 10 15 and then 20 and I did like 21-22 bc I had a extension on the ratchet. Everything looks pretty even as far as how far the studs stick out the top the head. And No were not 100% sure about the coolant leak I re used the bottom gaskets(which are like cardboard it felt like?) it doesn't look like it's leaking and I had it started for a couple seconds stall out Then kicked it again boom backfire
So how much white smoke?
Get us pics of the plugs
Sent from my SAMSUNG-SM-G890A using Tapatalk
Ok I'll get some pics and I'll try to get a video of the smoke and how it sounds. Might be a dumb question but say I called auto zone and asked for a 2 stroke leak down test and they said they had one but not for 2 strokes. Does it matter or does it matter
People have made them work.
But a trip to autozone and home Depot and you can have your own
Yeah.
But still get the coolant pressure tester. It's an easier tester to use
This is the left plug it's wet
This is the right plug
Yeah.
