On a stock stroke pump gas dunner 28mm carbs T-5 pipes what would your guys run? The driveline 68mm or cub 68mm
Sent from my iPad using Tapatalk
Soooo..
What happened to the stock cylinders?
That's the wife's bike and I was thinking doing mine but might as well spend a few more paychecks and do mine with a cub or maybe the driveline what ever seems to be better I don't know what's better and never had a cub so doing a lot of reading
What type of riding do you do? You're all over the place here. If you're on a budget port your stock cylinders. Either way you will be in more then $400. Considering the other work you would need.
sent from yo mammy house.
