hoppedupandcutdown Posted April 7, 2016 Report Posted April 7, 2016 The question is... Are your two carb bowls installed in the correct carbs? They are different from left to right. UNDERSTAND? 1 Quote
darkness878 Posted April 9, 2016 Author Report Posted April 9, 2016 in the bowls is says 1-1 1-2 Quote
darkness878 Posted April 9, 2016 Author Report Posted April 9, 2016 ill check when i get back home all my main jets and pilots came in today Quote
r_gillies Posted April 10, 2016 Report Posted April 10, 2016 Wow learn something everyday! Thanks hoppedupandcutdown Sent from my iPhone using Tapatalk Quote
darkness878 Posted April 12, 2016 Author Report Posted April 12, 2016 turns out my bowls were on the wrong side! Quote
darkness878 Posted April 14, 2016 Author Report Posted April 14, 2016 ok so 240 main jets installed bowls on correct sides, 30 pilot jets, where should i put needle 4th clip down is stock is 5th to much? Quote
hoppedupandcutdown Posted April 14, 2016 Report Posted April 14, 2016 3rd (middle) is stock, try that first. Quote
darkness878 Posted May 18, 2016 Author Report Posted May 18, 2016 all together having issue with adjusting pancake bearing now any advise? all brand new rod ball arm clutch cable? all torqued properly and aligned i have the casade brand i had the short rod in coudnt get arrows to line up Quote
