r_gillies
Everything posted by r_gillies
  1. we are a dealer for it up here in manitoba. Surprised small engine shops in the U.S. don't carry it. It is pricey but saves on any fuel system repairs or downtime. Our local fire departments use it as they can't chance something not starting or running properly when they are out on a call Sent from my iPhone using Tapatalk
  2. no problem cool truck btw. Have a great weekend! Sent from my iPhone using Tapatalk
  3. Ever hear of aspen fuel? Will eliminate all your carb issues. Shelf life of five years And if it does dry up leaves nothing behind to plug up jets. Sent from my iPhone using Tapatalk
  4. Thanks for AC Pro Pegs! My little guy couldn't wait to bolt them up! Sent from my iPhone using Tapatalk
  5. Our asphalt sled made a hair over 300 with stock turbo. Sent from my iPhone using Tapatalk
  6. My machinist said Pistons were tapered down at squish band no head mod needed. is it possible that using the thin cometic base gaskets caused this as oem are quite thick. Sent from my iPhone using Tapatalk
  7. Owned quad for about ten years now and it had a very hard life before me. Last fall went through crank and bored out cylinders to run 66mm wossner Pistons. Used proper engine gaskets for large bore. Stock timing, head, carbs. Pc pipes and midrange porting. Rode about 6 tanks and seized mag side crank bearing. Bearing piled up so hard it pushed crank apart. Upon closer look my Pistons are hitting stock factory head right at edge of squish band. I'd like any suggestions on how to properly modify a replacement head and approximately what it would cost. Thanks. Sent from my iPhone using Tapatalk
  8. Older 580 xlt had 34mm carbs maybe those are the ones your bud was referring to? Sent from my iPhone using Tapatalk
  9. What does a failed bearing have to do with air leak? Pressure test won't prevent mechanical failure. Sent from my iPhone using Tapatalk
  10. Wow learn something everyday! Thanks hoppedupandcutdown Sent from my iPhone using Tapatalk
  11. Sent payment for pro peg nerfs! Thanks! Sent from my iPhone using Tapatalk
  12. Pro pegs available still? Willing to ship north of the border? Sent from my iPhone using Tapatalk
  13. Bet there is 500 plus hours on mine. I'll post pics when I tear into it. Always use honda HP trans oil, clutch plates last a long time, oil stays very clean too. Sent from my iPhone using Tapatalk
  14. Pull plugs and have a look at them let us know what colour they are Sent from my iPhone
  15. What would you like to get for cylinders? Sent from my iPhone
