gregckrt1 Posted March 1, 2016 Report Posted March 1, 2016 Last fall I have gotten my shee back from the shop from a fixed stator and a couple miscellaneous things. Fresh rebuild And when I got home I figured I could go ride it so I get about 15-25 mins in and it starts leaking coolant out the over flow and then from the head. I let it sit all winter and have it a compression test yesterday it ran right up to 60 and stopped both sides could this be from the leak? Or could it be that I blew it up when riding it that 20 mins ? Sent from my LG-H900 using Tapatalk Quote
hoppedupandcutdown Posted March 1, 2016 Report Posted March 1, 2016 Well 60 is better than 0. Remove both spark plugs and the radiator cap and see if you get zero. Also, if it's a new cheap gauge, try it on something else and see if you get more than 60. Double also, looking back at your old threads, you know it's fucked up. Quote
Larry's Shee Posted March 1, 2016 Report Posted March 1, 2016 And if you let it sit all winter with coolant in the bearings, you might be doublely fucked. If the shop did the top end, why didn't you get ahold of them right away ?? Quote
gregckrt1 Posted March 1, 2016 Author Report Posted March 1, 2016 Well 60 is better than 0. Remove both spark plugs and the radiator cap and see if you get zero. Also, if it's a new cheap gauge, try it on something else and see if you get more than 60. Double also, looking back at your old threads, you know it's fucked up. Yeah I know I kinda just had to get away from it and ok I'll try when I get off work I'll let u know Sent from my LG-H900 using Tapatalk Quote
gregckrt1 Posted March 1, 2016 Author Report Posted March 1, 2016 And if you let it sit all winter with coolant in the bearings, you might be doublely fucked. If the shop did the top end, why didn't you get ahold of them right away ??They didn't do the top end they were suppose to look over everything and I called the day after and they said they can't ride it they can only start it up for a couple mins and that's when I hung up the phone lol Sent from my LG-H900 using Tapatalk Quote
gregckrt1 Posted March 1, 2016 Author Report Posted March 1, 2016 Also it was under a patio with a tarp on. Not was protected from the snow and rain Sent from my LG-H900 using Tapatalk Quote
sheerider11 Posted March 1, 2016 Report Posted March 1, 2016 Is it a good tester or a Harbor freight tester? Quote
Bennett131 Posted March 1, 2016 Report Posted March 1, 2016 Harbor n freight Sent from my LG-H900 using Tapatalk You should invest in a nicer one, or borrow a nicer one from somebody and try again. The HF ones are known to be fucky. Quote
gregckrt1 Posted March 1, 2016 Author Report Posted March 1, 2016 Yeah I hear the snap-on ones work great. N ur right I should have just gotten a better one but I figured hell what's 15 bucks Sent from my LG-H900 using Tapatalk Quote
gregckrt1 Posted March 1, 2016 Author Report Posted March 1, 2016 Do you think I was looking compression from the leak and can get new gaskets and torque everything down to the spec? I mean do u think it's a possibility ? The cylinders and head look clean no scrapes, dents or dings Sent from my LG-H900 using Tapatalk Quote
sheerider11 Posted March 1, 2016 Report Posted March 1, 2016 That test is no good. The reason I asked if it was HF is because I've seen many read 60 on everything they touch. Quote
gregckrt1 Posted March 1, 2016 Author Report Posted March 1, 2016 Oh ok well thank you Sent from my LG-H900 using Tapatalk Quote
87sheerips Posted March 3, 2016 Report Posted March 3, 2016 Ive had great luck with my Craftsman tester for a lot of years! 1 Quote
