BansheeBhoyJaay Posted March 1, 2016 Author Report Posted March 1, 2016 So I'm clear, you're referring to the lines that leave the bottom of the bowls and go to the ground? Yea Those Lines Have Always Been Leaking Since I Got It Quote
hoppedupandcutdown Posted March 1, 2016 Report Posted March 1, 2016 They are not supposed to. There is a small screw head that is bowl drain, clean it first, unscrew it, clean it again, screw it in until no fuel runs out. You may need to take the bowl off to clean it inside too. Quote
gregckrt1 Posted March 1, 2016 Report Posted March 1, 2016 Defiantly clean the carbs and make sure they're synced also what hoppedupandcutdown said use fresh gas Sent from my LG-H900 using Tapatalk Quote
BansheeBhoyJaay Posted March 1, 2016 Author Report Posted March 1, 2016 They are not supposed to. There is a small screw head that is bowl drain, clean it first, unscrew it, clean it again, screw it in until no fuel runs out. You may need to take the bowl off to clean it inside too. This Would Have To Be Done To Both, Correct? Quote
hoppedupandcutdown Posted March 1, 2016 Report Posted March 1, 2016 At least the one that is leaking. But yes - both that way you can open them to see if your carbs are getting fuel, and close them and not be a fire hazard leaking gas. Of course we've not even gotten to why it won't start. Except maybe old gas and plugged up carbs. Get your Clymers manual on order? Quote
BansheeBhoyJaay Posted March 1, 2016 Author Report Posted March 1, 2016 At least the one that is leaking. But yes - both that way you can open them to see if your carbs are getting fuel, and close them and not be a fire hazard leaking gas. Of course we've not even gotten to why it won't start. Except maybe old gas and plugged up carbs. Get your Clymers manual on order? Yea I Would Say It May Be A Problem From Having The Old Gas Sitting In There For A While & Trying To Start It With The Old Gas. I Am Going To Give It Fresh Gas & See What Happens. Also, Ive Tried Removing My Carbs But Its Way Too Tight For Me So Would There Be A Way Clean/Inspect Them Without Removing Them All Tha Way? I Havent Ordered The Manual Yet But I Am Going To Do So Today Or Tomorrow. Quote
hoppedupandcutdown Posted March 1, 2016 Report Posted March 1, 2016 you can just loosen the clamp and twist the tops "in" without taking them off to get to the bowl screws, just be careful and don't loose anything. clean everything first, keep the floor clean and uncluttered in case you do drop something. Work with plenty of light. Use a GOOD phillips screw driver. Do one carb at a time. Don't forget to reinstall the rubber tube between the carbs for the choke, it won't start without it. EDIT- it looks like you already have the airbox off, should be no problem to just pull the carb from the front boot and bring it up into the open there. Quote
Larry's Shee Posted March 1, 2016 Report Posted March 1, 2016 Don't want to be a dick, but you do realize you mix 2 stroke oil with the gas ?? Quote
BansheeBhoyJaay Posted March 1, 2016 Author Report Posted March 1, 2016 Don't want to be a dick, but you do realize you mix 2 stroke oil with the gas ?? Yea I Know That I Use Castrol That I Picked Up From Chapparel Quote
hoppedupandcutdown Posted March 1, 2016 Report Posted March 1, 2016 Yea I Know That I Use Castrol That I Picked Up From Chapparel MTX or TTS? Quote
BansheeBhoyJaay Posted March 1, 2016 Author Report Posted March 1, 2016 MTX or TTS? Castro 927 But Im Not Really Sure Quote
hoppedupandcutdown Posted March 1, 2016 Report Posted March 1, 2016 HaHa, That would be CASTOR 927, not Castro or Castrol. OK that's good oil Quote
BansheeBhoyJaay Posted March 2, 2016 Author Report Posted March 2, 2016 HaHa, That would be CASTOR 927, not Castro or Castrol. OK that's good oil Lol Whatever You Knew What I Was Trying To Say Lmaoo But When I Get Back To The House Im Going To Try The Rest Of The Stuff You Told Me & See What Happens Quote
hoppedupandcutdown Posted March 2, 2016 Report Posted March 2, 2016 Well not really, Castrol makes both a premix oil and a "2 stroke" oil, for transmissions. Both in very similar bottles. Just checking. Quote
BansheeBhoyJaay Posted March 5, 2016 Author Report Posted March 5, 2016 I Cleaned The Carbs Of The Old Fuel Put New Fuel In & She Started Up. Thanks I Really Appreciate Your Help. One More Question, If I Wanted To Spray Paint Her What Do You Think Would Be The Best Paint? Quote
