Digitall Posted February 27, 2016 Report Posted February 27, 2016 So I'm having the infamous right cylinder not firing problem. I bought the banshee with this problem thinking it was worn out cylinders. Got the cylinders machined with new wiseco pistons and rings, rebuilt the carbs , changed every seal on the motor. I ran through all the basic trouble shooting like switch plug wires, checked the choke tube, changed plugs, checked the reeds even changed carbs and i still have this haunting problem. When i had just rebuilt the top end it was firing fine, both pipes were running hot and idling ok, but now 4 days later the right side only fires at mid to high rpm. If i unplug the right plug wire the bike will start on the left only but will not start on the right side only. I have spark and its getting fuel also both cylinders have the same compression why is the right side not running? also in the mid rpm range it bogs like some kind of ignition cut maybe bad stator or cdi?? The TORS box on the carbs are disconnected and the TORS brain is also disconnected. not quite sure what year it is, the guy that sold it to me said it was a 2006 but its not, think its a 95 or so based on a few things . Please help I've pretty much tried everything and still can't get the right side to run right. Any help will be greatly appreciated! Thanks in advance. Quote
Digitall Posted February 27, 2016 Author Report Posted February 27, 2016 Plugged pilot jet its not firing in the mid to higher rpm range almost as if its not firing at all, just a occasional puff of smoke. i will check the pilot jet. thanks Quote
VegasJeff Posted February 27, 2016 Report Posted February 27, 2016 Mine runs that way when I have the parking brake on. Quote
Digitall Posted February 27, 2016 Author Report Posted February 27, 2016 Mine runs that way when I have the parking brake on. only on the right side? mine has no parking brake anymore. is there some wire i need to cut? thanks Quote
Phelps Posted February 27, 2016 Report Posted February 27, 2016 im gonna guess you're way too lean. the dominate cylinder will rob fuel even if the compression gauge shows them really close. if it's a smooth bog its a lean bog. you might try upping your jetting a few sizes to see if it improves or worsens. i would also do a leakdown. if the pto seal is pulling air it will cause a lean situation. Quote
Digitall Posted February 27, 2016 Author Report Posted February 27, 2016 im gonna guess you're way too lean. the dominate cylinder will rob fuel even if the compression gauge shows them really close. if it's a smooth bog its a lean bog. you might try upping your jetting a few sizes to see if it improves or worsens. i would also do a leakdown. if the pto seal is pulling air it will cause a lean situation. ok i will try upping the jetting and do a leakdown. btw what do you refer to as the pto seal? thanks Quote
Phelps Posted February 27, 2016 Report Posted February 27, 2016 "power take off" the clutch side crank seal. if it's pulling air in it will cause a lean condition on only that side. i would say look to the intake area as well, but if it was a problem before the new topend i would assume the only thing not changed was the crank seals. Quote
Digitall Posted February 27, 2016 Author Report Posted February 27, 2016 "power take off" the clutch side crank seal. if it's pulling air in it will cause a lean condition on only that side. i would say look to the intake area as well, but if it was a problem before the new topend i would assume the only thing not changed was the crank seals. i changed the crank seals before i did the new top end because the previous owner had the crank seal in backwards. thanks Quote
Phelps Posted February 27, 2016 Report Posted February 27, 2016 oh ok. yeah do a leakdown for safe measures and if it passes jump the jetting up ad see if it responds. Quote
Digitall Posted February 27, 2016 Author Report Posted February 27, 2016 oh ok. yeah do a leakdown for safe measures and if it passes jump the jetting up ad see if it responds. will do thanks Quote
Digitall Posted February 28, 2016 Author Report Posted February 28, 2016 Still having no luck... Any help would be greatly appreciated. Thanks Quote
Phelps Posted February 28, 2016 Report Posted February 28, 2016 are your carbs synced? maybe a lot of slack in the right cable and not opening on the right at the same time? Quote
hoppedupandcutdown Posted February 28, 2016 Report Posted February 28, 2016 so it passed leak down? Update us. 1 Quote
Digitall Posted March 1, 2016 Author Report Posted March 1, 2016 Having a little problem getting a leak down tester, I'm in Jamaica not the states... Apparently no1 has 1 here :|.... I did swap the carbs (from right to left) and took off the silencers , the right side pipes are now getting extremely hot and is spitting a lot of fire and also smoking a bit... Could be all that oil and fuel in the pipes burning up... Some kind of improvement but it's still not firing as smoothly as the left... Any ideas? Quote
