I was out for a long ride I was going fast for a long period of time and all of a sudden it starting going full throttle when I stopped in nuteral it kept doing the same thing loud what did I do did it blow up or how do I fix it thanks guys
leaned it out . probably toast. id do a compression test but i got a feeling you might just start tearing it down. they're not designed to be held wot for long periods of time without proper jetting.
Would it run back to normal since I fixed the air leak
It depends if you didn't do any damage while the cap was loose, as suggested be certain and a compression test to be sure!
