Hey I'm kinda new to the two stroke world, and my banshee won't even get close to revving high in gear but in neutral it's fine . I had this problem before and I replace and gapped the plugs, and clean the filter and worked, so I tried this again and it's not working. Any suggestions. I have a tors delete on it also. Thank you.
Clean the carbs one at a time so you don't get the parts mixed up. While you have them apart write down the jet numbers. Be sure to take main and pilot jets and emulsion tube out, they have small holes that you have to make sure are open.
Don't forget to install choke crossover tube.
