Driveline Cylinder Review Dyno Run Stock Stroke T5 Pump gas stock carbs
The 4mil low port cylinders come 190.5 which is 30mm from top of deck.
The 4mil high port is at 194.5 which is 29mm from top of deck.
I sell them machined/unplated so you can do what ever you like to them porting wise. Just give me a call if that's how you would prefer to get them. It's been really busy and the machining process takes a while so just give me a little time to make them.
  • 2 weeks later...
  • 1 month later...
