Can you not use profanity its rude were having a conversation about tools here mate.
Stop trashing people's threads with your non-sense...
Op impact driver, flywheel puller, compression tester, chain breaker/riveter, cable lube tool, torque wrench 1 in inch pounds and 1 in foot pounds, carb sync tool, clutch holder, and cordless impact gun should about cover anything you need to do
  • Like 3
Get a nice impact driver. Not a big impact gun, just one like the carpenters use. You can get impact rated quater hex to 1/4, 3/8, &. 1/2" socket adaptors. It makes tear downs a breeze. It makes those stubborn phillips come right out like butter. If you got a set of Allen heads that work on a socket, that's another bonus.
Most everything else was covered except the 32mm socket for pulling the clutch apart. With an impact, you won't need some janky handle tool to hold it all.
Edited by trickedcarbine
  • Like 1
Top of the line mechanics use top of the line tools. If it ain't top of the line you just ain't top of the line.
Agreed to a point, but it's just a screwdriver man...
Sent from my SM-G900V using Tapatalk
What does it take to build a leak down kit
Do a little searching on here and you will find threads on how to build a proper setup.
I can post pics of what I have I you need.
  • Like 1
