< stacks of gaskets here, but I seldomly re use them. However, I do grease them. It helps make sure no gasket material bonds to the cases. The less scotch pad and scraping you have to do on any surface the better.
on the clutch cover gasket? And why do you say that?
Yup, I actually hit the case side then the cover side with a smooth layer of grease. Then sit the gasket on cover then slide 2 bolts through it, pick it up and slide on.
Also when eliminating the key you follow the key switch down till it becomes two wires then connect the two right?
Get in contact with Corey. Kompulsive concepts on here. He can make you a harness with what ever you want. No splicing or guessing. Awesome prices too
Minuscule but I moved the light switch/ kill switch to right be hind where my left leg is and I got the kick start seal put on probably Friday i will finish up the rest of the clutch area
Going black with the cylinders and red with the head, but will that be all right or will the paint trap the heat in and make the motor run hoter? And I'm gonna get the motor ported and polished, with v force 4's then some dmc 916's and I've all ready got k&n pods and +4 timing so I think that should definitely be substantial on power any input?
Don't predetermine your pipes talk to your builder about what pipes compliment their porting. Some pipes will hold porting back.
that's very true haha I guess I was just getting ahead of my self, I think the first step will just be getting the porting done then.
