Remove the primary shit clean it all up really good with some sort of degreaser and load up the key with 1211 or hondabond. Reassemble.
Your going to have to pull the basket. It will just make shit easier. I'm sure you can sit there and prob work the primary gear free. But the time spent trying to do that you can just pull the basket.
Have  to put sealant on the keyway, huh? Says nothing about that in the manual, probably why I didn't do that. I will seal it up this afternoon and re-test. Thanks again.
That would be where your slight leak is coming from. Since you have it apart seal it, otherwise 6 lbs held for even a minute is a passing leakdown test to me. It wont effect your jetting or motor enough to worry about at all. You can even just yamabond the back of the washer and nut and call it good without taking the gear/basket etc off. It will be fine.
