kjh Posted November 28, 2015 Report Posted November 28, 2015 Crank has trued by Twister 4 rides ago. Flywheel end has some damage from flywheel coming loose. I ran it like this with no issues. Or u can have it repaired. $500 Sent from my XT1080 using Tapatalk Quote
Bennett131 Posted November 28, 2015 Report Posted November 28, 2015 Pics help things sell faster... Quote
kjh Posted November 28, 2015 Author Report Posted November 28, 2015 Working on pics, first time with this app Sent from my XT1080 using Tapatalk Quote
kjh Posted November 28, 2015 Author Report Posted November 28, 2015 Crank has trued by Twister 4 rides ago. Flywheel end has some damage from flywheel coming loose. I ran it like this with no issues. Or u can have it repaired. $500 Sent from my XT1080 using Tapatalk [ Sent from my XT1080 using Tapatalk Quote
kjh Posted November 28, 2015 Author Report Posted November 28, 2015 [ Sent from my XT1080 using Tapatalk Sent from my XT1080 using Tapatalk Quote
kjh Posted November 28, 2015 Author Report Posted November 28, 2015 Sent from my XT1080 using Tapatalk Sent from my XT1080 using Tapatalk Quote
SOUTHTHIRTY Posted November 29, 2015 Report Posted November 29, 2015 Your correct. . That is damaged 1 Quote
Bennett131 Posted November 29, 2015 Report Posted November 29, 2015 Might be able to sell it on fb for 500. Quote
SOUTHTHIRTY Posted December 2, 2015 Report Posted December 2, 2015 How would the flywheel key stay in there? Quote
Deadbeat Posted December 3, 2015 Report Posted December 3, 2015 thats fucked...you cant run that unless you weld the flywheel on Quote
gasmask34 Posted December 4, 2015 Report Posted December 4, 2015 if that not where the woodruff key goes then you can run it with no problem. my 16 an 18 mill did the same thing. it comes from the flywheel nut coming loose an causing an electrical ark. I used some type of electrical grease to stop ark and lock tight on the nut. Quote
xbig pitax Posted December 6, 2015 Report Posted December 6, 2015 Lock tight is a must on flywheels the vibration of the motor loosens it with out locktight Quote
J-Madd Posted December 6, 2015 Report Posted December 6, 2015 Lap the flywheel on, then cover the crank mating surface with blue locktight (as a barrier) before installing. That prevents 99% of such issues. 1 Quote
kjh Posted December 8, 2015 Author Report Posted December 8, 2015 i ran it with no issues for a long time. Quote
