gasmask34
Everything posted by gasmask34
  1. Do u still have the crank
  2. Wat do you have left?
  3. Thanks...motor was built years ago but can't find old domes. Had 2 sets cut. One for gas the other alky. Gonna use gas domes to have a set of alky domes cut.
  4. It's setup for 1/8 drag racing on 39 pwk alky.
  5. On a 14 mill cheetah what is the minimum an maximum piston to dome clearance allow. It's a dome piston. Piston rim is flushed with cylinder.
  6. 29L is a long rod
  7. 29L is a long rod
  8. gasmask34
    Swingarm
    Got one
  9. I no this is an old post but do u still have that crank?
  10. gasmask34
    Swingarm
    Banshee plus 10 round house
  11. Pm'ed you...
  12. Still have these
  13. if that not where the woodruff key goes then you can run it with no problem. my 16 an 18 mill did the same thing. it comes from the flywheel nut coming loose an causing an electrical ark. I used some type of electrical grease to stop ark and lock tight on the nut.
  14. Yea that's wat bitches do.
  15. Possum, keep ur thoughts any opinions to yourself. If u cant put out helpful information continue suck Dicks. That's all ur mouth is good for. U got something smart to alot of post. Keep out of people post if u can help.
  16. Thanks
  17. So start with 17/38 gearing. If I need more do I go up on the front sprocket or the rear sprocket?
  18. Not wanting to pay that much
  19. Thanks
  20. in 1/8 mile drag im running a 19/34 f/r sprocket. its pulling well pass an 1/8 mile. do I need to go up on the rear sprocket or go down on the front sprocket. trying to get the most in 1/8 mile. after that the race is over.
  21. Anyone has one for sale?
