Sup guys just finished my rebuild bike started first kick
Second day nothing 3rd day it started up idled fine for about 10 min or so then i killed it wanted to fire it back up and nothing and its been dead ever sence really frustrated just dont underatand how it fired up fine one day and the next nothing....someone ever had these issues
No spark to the plugs tryed disconnecting the tors box and still nothing gna order the puller
And coil
But what the heck is going on how can it run so good then just die like that
Well honestly the wire looks like shit but bought the bike like that and when it fired up figured everything is wired rite but good idea ima rip out the harness and see whatsup
You may search some of my previous posts on electrical tests.  There is no reason to go swapping parts around without knowing they are good or bad.  The stator coils and flywheel can be easily tested with a basic 5w nightlight lightbulb.
9/10 times, if the resistance checks at the stator pass, the stator is fine.  However, the flywheel magnets can break causing a loss in magnetic flux which induces the AC voltage from the stator.  Lightbulb test will confirm everything at once.
Brandon
Mull Engineering
Brandon
Mull Engineering
Ground wires FTW!
