Woah. I'd pull the caps trim the wore back. Ohm the caps, ohm the coil.
Can you explain a bit sheerider. I've never done that before . Thanks I appreciate it .
Do you know how to use an ohm meter?
I'd pull the caps ohm them. Just unscrew them off the wires. Trim the wires back 1/4" and ohm the coil.
What size are your pilot jets, and did you take them out of the carbs to clean them?
I pulled them out to clean them and they didn't have a number on them . Any other way I can find out ?.
I own one, I guess I'm learning today. What reading should they be at ?.
Before you physically pull it apart do all diag you can. Would suck to find out a bad cap caused all this
But wouldn't the problem follow the plug if it was a bad cap?. I already tore the whole bike apart cleaned and checked everything except the Pistons . I noticed my TORS kits are unplugged so I'm going to get the delete kits. That's all I found that was wrong .
I honestly didn't read through the thread. Did you change the plugs?
Sent from my SAMSUNG-SM-G890A using Tapatalk
yes sir I did . I just posted pictures of the plugs with a couple test runs on them .
They have a number on them somewhere, but those numbers are really small.  I'd remove them from the carbs, and let them soak submerged in some carb cleaner for a while.   Use a magnifying glass to find the numbers, if you need to.
Thanks for the advice I really appreciate it . That's about the only thing I have not done . I'll pop the head off and check. What exactly will I be looking for ?.
Inspect for any damage on the piston and ring areas or any other obvious scaring of internals. Take a good peek at the dome and piston crown, even if there isn't any major nicks, pitting, or scaring, look for small "ghost" circle patterns. You could be suffering some detonation issues. Has the bike backed out any plugs or popped the porcelain loose?
That's bro ill do that.
Nothing at all the plugs are good I checked the old ones and they were fine too all in tacked . I'll remove the head and check for signs of wear like to described . Thanks for all your help guys .
Just pulled out my idle jet to check if it was clogged it's a 32.5 . I'm going to replace them with new ones just incase. Should I stay with the same size or change them ?.
