blackedout96 Posted August 30, 2015 Report Posted August 30, 2015 Clean, well kept '07 Renegade with the following... -Garrett GT15 Turbo -Ceramic coated exhaust -Powdercoated piping -Custom Intercooler -Blow off valve -Boost sensing Trask fuel controller -Boost gauge -Innovate MTX-L air/fuel gauge -Turbosmart boost controller -BRP Race department ECM with modded map for turbo -Green '09 Injectors(higher volume) -VFJ primary with 3 position adjustable weights -Elka Stage 3 front and rear shocks You can dial the boost up or down depending on your riding area. Can run as low as 2psi and as high as 12 with the current map. 9 is generally as high as I go and it's a pretty insane ride at that. Intake/air filter and bov are located inside the oem air box so you are just as capable of riding mud or other wet areas as you would be with a stock machine. $8,500 Anyone interested in more details or pictures just let me know. Located in Edwardsburg, MI Quote
special06shee Posted August 30, 2015 Report Posted August 30, 2015 Fuck i want this. Hard to beat the feel and wow factory of a turbo setup. Quote
87sheerips Posted August 30, 2015 Report Posted August 30, 2015 Why not keep this bitch Mike? Also WHY haven't you been over to ride??????!!!! Track is ready for you. Quote
blackedout96 Posted August 30, 2015 Author Report Posted August 30, 2015 Yeah fellas this thing is a beast, whoever ends up with it will be very happy. Riding it til it sells JD, then on to the next project. Going to the u.p. this weekend, but might come out next weekend. Quote
87sheerips Posted August 31, 2015 Report Posted August 31, 2015 Yeah fellas this thing is a beast, whoever ends up with it will be very happy. Riding it til it sells JD, then on to the next project. Going to the u.p. this weekend, but might come out next weekend. Me and katie will be in st. Ignace/mackinaw this up-coming weekend.... May bring Rzr but doubt it Quote
Deadbeat Posted August 31, 2015 Report Posted August 31, 2015 awesome bike what sort of weight and horsepowers Quote
blackedout96 Posted August 31, 2015 Author Report Posted August 31, 2015 9psi is right at 100hp to the wheels. Weight is around 700lbs wet 1 Quote
sheerider11 Posted August 31, 2015 Report Posted August 31, 2015 9psi is right at 100hp to the wheels. Weight is around 700lbs wetThat's so cool. Quote
Bennett131 Posted August 31, 2015 Report Posted August 31, 2015 Just for amusement purposes, do you have any videos of this thing running? Quote
blackedout96 Posted August 31, 2015 Author Report Posted August 31, 2015 Just took this one for a buddy that wanted to hear the turbo. Find myself riding alone for the most part lately so no actual riding videos. https://vimeo.com/137896021 Quote
blackedout96 Posted August 31, 2015 Author Report Posted August 31, 2015 ...and of course the sound isn't working in the upload Quote
blackedout96 Posted August 31, 2015 Author Report Posted August 31, 2015 This should work http://youtu.be/IscRKNeLW2U 1 Quote
