I just received 573M06800 pistons. Domes are supposed to be 69mm 21cc. I don't see any spacer plate in the box.
Crank from hotrods is supposed to be 4111. I think something is wrong. I thought for long rods I needed 795M06800 pistons...
Please help me out
The pistons you have are blaster pistons. The 795's do not come in the 68mm bore size so guys use the blaster style.
The cylinder is cast with the proper geometry to not need a spacer plate or stepped domes.
Allright boys. What jets would you recommend for 421 fully ported for "trails" Shearer small bore, air box lid removed, ground sea level, Pro Flow by pro design with their special K&N air filter, 35MM PWKs
165 main 50 pilot cel needle 4 th clip
In your opinion as a builder. If I am doing a high dollar build and was having a CP mono jug ported, would I be having to high expectations to expect the little casting nubbies at least be sanded off? Just curious, if it's common or not and wondered as I'm taking the plunge.
165-168 main
Dyno jet needle? From stock carbs or for keihin 35mm PWK's
55ish pilot.
  • 5 years later...
