antneebriscoe Posted August 15, 2015 Report Posted August 15, 2015 My banshee powerbands will not kick in after top end rebuild I'm needing help Sent from my iPhone using Tapatalk Quote
camp0429 Posted August 15, 2015 Report Posted August 15, 2015 First post in correct section, then list mode and details Quote
Deadbeat Posted August 15, 2015 Report Posted August 15, 2015 did you put right powerbands back in 3 Quote
rjdgriff Posted August 15, 2015 Report Posted August 15, 2015 If you don't align your powerbands with the cam shaft position sensor, they will not engage due to your timing chain running backwards 5 Quote
special06shee Posted August 15, 2015 Report Posted August 15, 2015 Have pistons in right way? 1 Quote
camp0429 Posted August 15, 2015 Report Posted August 15, 2015 First post in correct section, then list mode and details *mods was supposed to say. But yeah, powerbands color and timing makes a huge difference 1 Quote
antneebriscoe Posted August 15, 2015 Author Report Posted August 15, 2015 Bored .90 v force 4 reeds stock carbs with 240 main jets Sent from my iPhone using Tapatalk 1 Quote
antneebriscoe Posted August 15, 2015 Author Report Posted August 15, 2015 Lost all power could carbs be out of sync Sent from my iPhone using Tapatalk 1 Quote
antneebriscoe Posted August 15, 2015 Author Report Posted August 15, 2015 Pistons In right had motor took to specialize builder Sent from my iPhone using Tapatalk 1 Quote
hoppedupandcutdown Posted August 15, 2015 Report Posted August 15, 2015 slides back in the correct carbs? Quote
lil Doobie420 Posted August 15, 2015 Report Posted August 15, 2015 needs a super specialized tuner now 2 Quote
Larry's Shee Posted August 16, 2015 Report Posted August 16, 2015 Sounds like he didn't put the specialized poer bands in (correctly ) As Elvis youst to sing " Return To Sender" 1 Quote
antneebriscoe Posted August 16, 2015 Author Report Posted August 16, 2015 Lol u maybe right Sent from my iPhone using Tapatalk 1 Quote
lil Doobie420 Posted August 16, 2015 Report Posted August 16, 2015 i only use red power bands.... 2 Quote
