Im building a xc/trail quad and would like to hear how you guys have your bike set up. Right now im in the processe of building my engine. This is a ground up build so my options are wide open at this point. So far for the engine it will be 10over either rebuild stock welded crank or maybe a hot rods 4mil, k&n no lid, boysene reeds, stock carbs, no porting, and either a stock shaved head for now or a cool head if funds allow it. Im still in the air on what pipes i have a set of t3s i thought about making them fit a a arm frame, but have read they are more of a top end pipe. Any pointer and options are welcome thanks.
when i built mine i had it in mind that i would be riding longer distances,definetly look into a aftermarket gas tank i went all in with the clark tank 5.5 gallons nothing like almost never having to worry about gas when your out there my favorite sand hills and trails are a 4 mile ride there and another 4 back and i usually run out of gas before the shee does, my engine is a 421 cheetah with powervalves, the powervalves are great when your in the trails you dont have to shift as much when your up and down in speed, any nice aftermarket shock with do just great on the trials, i run custom noss head 20cc domes +4 timing, oh and crank is 4 mill i love the set up for the trials around here
Edited by bansheelapointe
Quick sand +2+1 aarms
Fireball +6 swingarm
Elka stage 3 shocks all the way around
35 pwks
Sniper pipes
Redline 10mil serval (cool head, straight cuts, vf4 reeds, +4 timing, lockup clutch, pod filters and pump gas)
  • Like 1
XC and trails vary and the set-ups associated with them. Here in Colorado the folllowing setup has been killer for me. I ride between 6,000' and 12,000'.
2006 Banshee
Roll Design, Lobo 2 XC package
Axis Shocks
Herman stem w/ 1-1/8 clamp
5 gallon tank
Twist throttle
AC Pro Peg nerfs
RPM front hubs
Douglas Billet Shamrocks
ITP XCs
Stock bore and stroke
Milled head
V-Force 3s
Trinity 2-1 (port matchd to the reed cages)
33mm carb
stock air box
K&N filter and air box lid
PT mids
Toomey silencers w/ spark arrestors (we fabed these up to fit the PT mids)
Evans coolant
Pump gas - Yamalube 2R
160lb jockey
A 50 mile loop is common for us and the pace is really fast for the entire ride. I cant imagine trying to run my modded motor in my XC set-up. I have never needed more motor for the trails we ride.
Good luck with your build.
  • Like 1
  • 2 weeks later...
4 mil pump gas
+2+1 arms
Stock length swing arm
Axis front pep rear suspension
Flexx bar
LSR anti vibe stem
Hiper rims
Other shit. I like it. My bike makes way more power then needed. It's closer to a dune bike then a trail bike. But I have no dunes. So I put a dune motor in a trail chassis.
stock
clapped out and fucked everything
out of sync carbs
out of phase crank
scratched warped plastics
no rad shroud
tors
bald tires
bent a-arm
one headlight pointed at my face coz my futures so bright i gotta wear shades
naked barbie doll zip tied to the cross bar
butt plug duck taped to the seat to lock me in when im hitting the whoops
i dont do whoops
bootlegged BHQ sticker
  • Like 1
stock
out of sync carbs
out of phase crank
no rad shroud
tors
bald tires
bent a-arm
i dont do whoops
Where did you get your build sheet? craigslist?
