theputz Posted August 11, 2015 Report Posted August 11, 2015 I currently have a 421 serval and have pondered the idea of upgrading to a 521 super serval. Passed on what i have seen i could potientially see a 20hp increase if built correctly. I am curious how many parts will transfer over. Will my noss head and intakes/reeds work with a super? I believe my 39 pwks and shearer oof sb pipes will work... Quote
trickedcarbine Posted August 11, 2015 Report Posted August 11, 2015 A considerable amount will transfer. Head set up is about the only real difference. May wanna consider big bore pipes though if you stay shearer. Maybe Snipers or something custom If you can afford to do it. If you can afford to go bigger, go for it. Quote
RagunCajun Posted August 11, 2015 Report Posted August 11, 2015 I run 39's on my 521 serval. Only went with that because my builder suggested it. I can't help with what will transfer over. Mine was very expensive but i really didn't have anything left from my old 4mil I could use. Hoping to finish it in two months. Quote
theputz Posted August 11, 2015 Author Report Posted August 11, 2015 So what would i need to look at; Head and domes, crank, ported cylinders, pistons and maybe pipes? I have a lock out, modded tranny, straight cuts and billet basket. Quote
trickedcarbine Posted August 11, 2015 Report Posted August 11, 2015 So what would i need to look at; Head and domes, crank, ported cylinders, pistons and maybe pipes? I have a lock out, modded tranny, straight cuts and billet basket. Correct. Quote
RagunCajun Posted August 11, 2015 Report Posted August 11, 2015 And someway to put that power to the ground. Good luck with that! 1 Quote
theputz Posted August 12, 2015 Author Report Posted August 12, 2015 Hahah gust you know you will be in the loop if I pull the trigger Quote
salmon_slayer06 Posted August 24, 2015 Report Posted August 24, 2015 When building a 421, do you replace the case studs with longer ones to hold the cylinders? Quote
trickedcarbine Posted August 24, 2015 Report Posted August 24, 2015 You can, I have a set of cub cases here with actual longer studs. Most folks run ARP stud extenders. Quote
rjdgriff Posted September 7, 2015 Report Posted September 7, 2015 465 serval will give you 100hp if done right on pump gas Quote
mike0chek Posted September 9, 2015 Report Posted September 9, 2015 i will be def going to a larger top end when my 421 needs attention 1 Quote
pablopab50 Posted September 12, 2015 Report Posted September 12, 2015 I bet with 521 super serval you can beat 421 cheetah cubs Quote
