  • 1 month later...
Damn guess someone would have gave some sort of response. But i dont see it being the cases if the crank bearings sit good and tight in the case. Sounds to me like the flywheel is not on perfectly centered or out of whack and causing a slight vibration. From what i have read and understand if the shaft key isnt in just right it can cause flywheel not to seat right. Or maybe crank seal isnt sealing well and not keeping bearing lubed well. Just some thoughts.
