Shaun Amori Shawna
Everything posted by Shaun Amori Shawna
  1. 717 Sent from my HTC One_M8 using Tapatalk
  2. I could both bro. Tez 7176179723 bro. Sent from my HTC One_M8 using Tapatalk
  3. Hit cell 7176167923. Sent from my HTC One_M8 using Tapatalk
  4. I got everything you need brother Sent from my HTC One_M8 using Tapatalk
  5. I have a j frame. And I nodt any it wit is and powered counted. So that me no the bro. 6179673 Sent from my HTC One_M8 using Tapatalk
  6. I take the front bumper s. Hit me u 6169729 bbro. Sent from my HTC One_M8 using Tapatalk
  7. I take clutch case hit me u at 6179723 that's Sent from my HTC One_M8 using Tapatalk
  8. U still got them bro. Hit me at 6179723. That's bro. Sent from my HTC One_M8 using Tapatalk
  9. CRANK was a new hotrod 4mill crank
  10. I was looking to get of 28m carbs for my 4mil build or is all rite to run shock ones. What size jets will be good. Thanks guys
  11. No the CRANK not fucked up. Its a 4mil crank. The case are to different cases. I did leak down test before and had no problem. The bearing is ALL BALLS BEARING. THANKS GUYS.
  12. I blew two stator side bearings. You guys it's my stator side case out of around making them to blow. Thanks guys
  13. This is the 2x my stator side bearing went out. You guys think my case is shot and messing my stator side bearing up. Thanks guys
  14. Will he bench test the motor when he is done with it
  15. Thanks for that brother igo with him
  16. How good is FAST MOTOR BUILDER.
  17. The gaskets for the jugs should I put yamaha bond between them when I put the jugs back on or should not put sealant on gaskets. Thank s guys.
