thet3chnician Posted April 23, 2015 Report Posted April 23, 2015 easy one here guys. ive gotta replace my chain and was wondering if anybody thought one chain is better than the others or if theyre all the same and i should just go with the one i find for the best price. thanks! Quote
sheerider11 Posted April 23, 2015 Report Posted April 23, 2015 The colored eBay ones to match your bike! Seriously, buy a good chain. I've had awesome luck with my Regina gold chain 2 Quote
Tyler S Posted April 26, 2015 Report Posted April 26, 2015 Get an o-ring chain or x-ring, they last 10 times as long as a standard roller chain. Always change your sprockets too, if not it will wear your new chain very quickly. As for getting a cheap chain I would try and get the best you can with your budget. Especially on a banshee with so much power the last thing you want to do is break a chain, it will probably wreck your engine case if it does break. Finally, if you get a colored one it will add about 9hp. Quote
roblipka6banshee Posted May 2, 2015 Report Posted May 2, 2015 I stick with the gold DID chains. Also replace sprockets at the same time. Sent from my iPhone using Tapatalk Quote
Dixie normus Posted May 3, 2015 Report Posted May 3, 2015 I run EK chain. Buy the best you can afford. O ring or x ring for sure Quote
trickedcarbine Posted May 3, 2015 Report Posted May 3, 2015 EK or RK. Starting to see stellar results with the Driveline stuff and will probably use it next go around. Quote
