thet3chnician
Everything posted by thet3chnician
  1. easy one here guys. ive gotta replace my chain and was wondering if anybody thought one chain is better than the others or if theyre all the same and i should just go with the one i find for the best price. thanks!
  2. Motofast 2 into 1 billet aluminum.
  3. Yes I went from left to right not front to back...
  4. I've got a single 40mm lectron carb on my setup and need to replace the intake manifold boot. Does anyone know the actual size of boot because I read on another site that lectron goes by air inlet size. Actual boot size should be 38mm. Can anyone confirm and where can I find a new boot for cheap?
  5. It's a 4mm striker so the plate should be about 2mm???
  6. @bigweav81 I believe my plate is 4mm or thereabouts.. I havnt put a caliper to it. What is my best bet as far as tightening up my squish band?
  7. And I'm running 20cc domes.. Before I rebuilt the top end the previous owner ran 19cc domes so could this have anything to do with the huge squish I've got? (.078-.080)
  8. So I don't believe I need custom domes I just need to skinny my spacer plate. The other concern I had would be port timing but would that be effected by such a small move in the cylinders?
  9. My pistons come to just below the cylinder deck at tdc.
  10. I've checked it with just the plate no gasket.. The spacer plate takes o rings but they were ruined when I pulled the jugs off. So checking squish I just torqued everything down with just the plate but it should be the same since it only takes o rings and would seat metal to metal regardless.
  11. No, I've got pd cool heads with 20cc domes.
  12. It's got a 4mm tdr stroker in it so they put a 4mm spacer plate below the cylinders. It was this way when I bought it. I've got to replace the plate gaskets anyways so I was wondering if someone sold a spacer plate with gaskets that I could use instead and then tighten up my squish as well.
  13. I've done a squish on both of my cylinders and both came in at around .078 to .080 is this too much or can i run it. if its too much I'm thinking all i have to do is get a new cylinder shim kit and gaskets.
  14. Thanks and will do.
  15. Ahhh ok so its without a doubt possible then. Thanks for the help!
  16. Also while I'm on a roll, I've got a 4mm doukas stroker in my machine with a 4mm spacer at the bottom of the jugs that takes orings that need to be replaced. Anyone know of or seen something similar. I couldn't find any numbers on the spacer plate. It's got 4 separate orings, each side top and bottom.
  17. Hey everyone im new here but im hoping you can help. I've got a 2into1 motofast intake manifold with a 40 mm lectron carb feeding it. My left side piston looks horrible like its been detonating and my right side appears to be fine(possibly even rich). My buddies and I did a leak down and found the cases leaking bad but wouldn't this effect both sides or is it possible it got to one side before the other. Thanks for any help!
