Hey guys new to the fourm and wanting to get Ito flat track. I'm a machinist and have any cnc/manual lathe/ mill at my disposal. I was just wondering what you Guys are making that actual sway bar out of. And where you guys are mounting them. Thanks for any help in advance
As a machinist, I'm assuming you have some grasp of metallurgy. Look for something known for high tensile and memory. That said, I'm not sure what my Rath's torsion bar is made of, but I think with a little research, you could find a nice piece of bar stock. For the same of ease, use something that has an outer diameter that fits inside a metal/carbon fiber tube. Mounting can be done any where, but IMO the lower the better if you're fabbing it. Guys are using the A arm bolt holes with brackets for the tube.
4130 will be fine, tube would be better than solid, od.and thickness is down to each set up and driver style.Make it in a way so it is easy to swap for a different spec one without having to rebuild the whole system.
