Tyler S Posted March 30, 2015 Report Posted March 30, 2015 On the left side the front hole is almost stripped, the back hole stripped so I drilled and tapped to 12x1.25. It stripped again, anybody else have this problem, if so how did you fix it. People say they have welded studs in but how would the peg mount flush to the frame with a bead of weld there. Also heard of people welding a flanged nut in there also, that sounds like a good idea I just don't no if it will be that strong when its done. Any help would be much appreciated, thanks. Quote
Tyler S Posted March 30, 2015 Author Report Posted March 30, 2015 On the left side the front hole is almost stripped, the back hole stripped so I drilled and tapped to 12x1.25. It stripped again, anybody else have this problem, if so how did you fix it. People say they have welded studs in but how would the peg mount flush to the frame with a bead of weld there. Also heard of people welding a flanged nut in there also, that sounds like a good idea I just don't no if it will be that strong when its done. Any help would be much appreciated, thanks. Quote
trickedcarbine Posted March 31, 2015 Report Posted March 31, 2015 http://bansheehq.com/forums/index.php?/topic/179491-stripped-footpeg-insert-in-frame-help/?view=getnewpost Quote
trickedcarbine Posted March 31, 2015 Report Posted March 31, 2015 Look at the second pinned thread... Quote
sleeper06 Posted March 31, 2015 Report Posted March 31, 2015 I've done both , flanged nuts and solid slugs, both look good when done and never had a problem with strength.as long as your welder knows his shit Quote
Tyler S Posted March 31, 2015 Author Report Posted March 31, 2015 How am I supposed to get the old ones out. Am I going to have to cut them out with a grinder? Quote
possum Posted March 31, 2015 Report Posted March 31, 2015 ive welded nuts in many times. You have to counter sink it enough and bevel existing hole to get a nice bead on it and grind flush.yes its strong, strong as the nut and bolt normally are. And its cheap Quote
Phelps Posted March 31, 2015 Report Posted March 31, 2015 i used stellar's kit on my last chassis. worked and looked good Quote
trickedcarbine Posted March 31, 2015 Report Posted March 31, 2015 Did not know stellar had a kit. Is it just weld in bungs? Quote
rjdgriff Posted April 1, 2015 Report Posted April 1, 2015 I ran all thread all the way through the frame on the back, and drilled out the front holes and used allthread in the front as well Quote
registered user Posted April 1, 2015 Report Posted April 1, 2015 ill take your word theyre 12x1.25 . thats a good size bolt. how the hell did you strip it Quote
Tyler S Posted April 3, 2015 Author Report Posted April 3, 2015 ill take your word theyre 12x1.25 . thats a good size bolt. how the hell did you strip it The whole was already pretty ovaled out. Even with the drilling I didn't get a good cut with the tap. It's an 87 so its seen a lot of action. Quote
