gunner88 Posted March 30, 2015 Report Posted March 30, 2015 (edited) Hey everyone thanks for the add. I just bought an 03 banshee. I've never owned one before. I did a compression text the other day and both cylinders are about 110psi, is this ok? A friend of mine says I should rebuild it. Plus it idles real low. I mostly trail ride with the occasional sand/gravel pit. Just wondering where I should start. Thanks for the help. Edited March 30, 2015 by gunner88 Quote
trickedcarbine Posted March 30, 2015 Report Posted March 30, 2015 It's getting there on compression, but that's just fine. Stock they're only like 130. Keep running it and start saving for a rebuild. The idle can be turned up easily. Quote
Larry's Shee Posted March 30, 2015 Report Posted March 30, 2015 Also try another tester. Adapter should be same length as spark plug. WFO and kick until needle stops moving. Quote
