Ok just got it all back together,took it for a test spin get back in the shop and it's leaking coolant from two of the studs on the bottom. But I do not see any in the oil.any ideas as to why? Suggestions
I had a torn o-ring on the tube into the clutch cover do that. Since the gasket was good all the way around the tube, coolant did not get into the trans area, but it did leak onto the top of the motor and through the hole in the middle and off of those studs underneath.
