timothy kaim Posted March 15, 2015 Author Report Posted March 15, 2015 I don't see any other markings Quote
trickedcarbine Posted March 16, 2015 Report Posted March 16, 2015 Ok, those were definitely cut by hand by someone other then Pro design. Quote
timothy kaim Posted March 16, 2015 Author Report Posted March 16, 2015 Yes I'm gonna try the squash test Quote
timothy kaim Posted March 16, 2015 Author Report Posted March 16, 2015 U think they are cut correct being that they are scribed Quote
trickedcarbine Posted March 16, 2015 Report Posted March 16, 2015 Depends. Typically whoever ports, is responsible for cutting domes so it's right. But seeing that there was a metal head gasket in there that shouldn't have been, it makes me wonder if someone just pieced a motor together and they are some random 4mm domes. Just put it together and measure it. It is the only way to tell what you got. Quote
timothy kaim Posted March 16, 2015 Author Report Posted March 16, 2015 K will let ya know the results.thanks Quote
timothy kaim Posted March 21, 2015 Author Report Posted March 21, 2015 Ok this is what I've come up with i did it 4 times left side was.87 right is.90 Quote
trickedcarbine Posted March 21, 2015 Report Posted March 21, 2015 Holy cow! That's mighty excessive. You wanna be about .045 minimum and .060 max. What type of base gasket is in there? Quote
timothy kaim Posted March 21, 2015 Author Report Posted March 21, 2015 I just have the o rings on the cool head And a cosmetic under the cylinders.the head isn't torqued it's just snug Quote
hercalmighty Posted March 21, 2015 Report Posted March 21, 2015 You have to make sure everything is tortured to spec first. Do you know how thick your base gasket is? Quote
timothy kaim Posted March 21, 2015 Author Report Posted March 21, 2015 I'll check when i get home Quote
timothy kaim Posted March 23, 2015 Author Report Posted March 23, 2015 Alright new squash results with head torqued down Quote
timothy kaim Posted March 23, 2015 Author Report Posted March 23, 2015 Yes sir thanks tricked!!i woulda never known to check this. Quote
