I just bought a 02 banshee all stock. I just put a FMF full exhaust on it will not run right now I changed to the jets to what they gave me and it still won't run right now he right cylinder is not firing until the power band kicks in .... Any advice is much appreciated
FFS. changing to fmf pipes wouldnt have nothing to do with it. what do you meen the right cylinder isnt firing ? is it completely fukin dead or just low on power ?  sounds like you need some professional assistance
assuming it ran fine before you swapped pipes, it should still run fine.   regardless if you messed with the jets or not. sounds like it wasnt running right before the pipe swap
Edited by registered user
That jetting should be a tad richer IMO. However, a dead cylinder is another issue. Thoroughly check over carbs, and start checking simple electrical stuff. Roached plugs, plug caps, pick up gap, coil ground is clean, wire harness condition, etc.
