I just recently put a different stator on my banshee and installed a battery with some sweet LED's. I took off my fmf fattys and put on cpi's and took off my v force 3 reeds and put on v force 4 reeds. I didn't jet it. It ran awesome at home (elevation is sea level) and then I went to sand lake and on my first flippin ride, it ran like crap and started shooting blue flames out of the right exhaust. So I took it back to camp and looked at it a little bit and couldn't figure out the problem. I tried different plugs and switched the coil, cleaned the carbs thoroughly. It's never been rebuilt. It will idle but when you give it throttle, the left cylinder runs fine but the right cylinder will bogg and then backfire like it shoots out air. It had good spark when I put the stator on because I checked it. The reeds are brand new, it starts fine, I think fuel is dumping through the cylinder but idk. It's been a long time since I messed with it because it was pissing me off. I took my right pipe off and the rings don't look like they have much life left. Idk. It's almost time for the dunes so I need to figure this out.
04 Banshee
Never been rebuilt
Stock motor
Cpi inframes
Vforce 4 reeds
Still have TORS
New stator
LED's
04 Banshee
Never been rebuilt
Stock motor
Cpi inframes
Vforce 4 reeds
Still have TORS
New stator
LED's
what brand stator?
If start there. And you don't know what's in it now. You didn't do a leak down when you pulled the reeds and replaced them.
