I have an 03 banshee with fmf pipes uni air filter tors delete kit and vforce4 reeds pretty much everything else engine wise is stock. Got it in a trade and the guy said it just needed some tuning. So I tried tuning it and it was always acting the same so I decided to get a carb rebuild kit for it. It came with all stock jets so I rebuilt them and put the slides in started it tuned it and synced the carbs. It idles pretty well and revs up fine but when I run it down the street to see how it did it ran like crap. It smokes alot more out of the right pipe and it revs up really high but doesn't really hit powerband how it should it bogs while it revs out then when I took it back to my house it was idling really high and smoking alot out of the pipes but the right still smoked more. I checked the slides again and they were still in sync. The bikes been sitting for a month idk what it is.
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
Probably so but you will work your way down. #2 because the bike is under a load when your moving. It amplifies the effect of a bad tune. Use my bike for example. It was bone stock and ran like shit when I got it. 200 mains/25 pilot. As I tore it down when I got home and learned it had a k and n filter. That's all! No pipes, no aftermarket reeds etc. the banshee would would run and idle for days but once you took off down the street, it wouldn't do worth a damn.
