BANSHEEBEEFM2M Posted December 7, 2014 Author Report Posted December 7, 2014 Using 3&3 now w/dd lockout +10 arm 73 to 10 paddle SLS haulers Quote
sprinklerman Posted December 7, 2014 Report Posted December 7, 2014 Using 3&3 now w/dd lockout +10 arm 73 to 10 paddle SLS haulersShould be fine then. Quote
BANSHEEBEEFM2M Posted December 7, 2014 Author Report Posted December 7, 2014 That's all? Keep 3/3 or should I put 6 stiff springs. Running 3 drive line drag springs and 3 oem Quote
BANSHEEBEEFM2M Posted December 7, 2014 Author Report Posted December 7, 2014 Most of my comp is on fb lol .. But I Bought proven setup off a builder in my area. Cases/jugs/domes/crank and his shearers n pwks. Gonna be a 421 cub here soon, I just wanna get my moneys worth out of this motor before I tear it down I just rebuilt it Quote
dozer Posted December 7, 2014 Report Posted December 7, 2014 3 stock 3 stiff 60 grams of weight. i imagine you could use less weight but with a 18dm,alky, oof, 76+ro extremes and 225lb rider mine has never slipped. Quote
BANSHEEBEEFM2M Posted December 7, 2014 Author Report Posted December 7, 2014 Shee slips a bit off the line now to were I actually have to hold the rear brake before I launch. Is that good or bad? Quote
n2otoofast4u Posted December 7, 2014 Report Posted December 7, 2014 Slips? Brakes? You mean it creeps when you rev it up in gear with the clutch pulled in? Quote
sprinklerman Posted December 7, 2014 Report Posted December 7, 2014 Shee slips a bit off the line now to were I actually have to hold the rear brake before I launch. Is that good or bad?That's not the clutch slipping, it's lurching,,not completely disengaged for some reason. ( notched basket, warped steels, frictions swollen, cable stretched ,etc) Quote
BANSHEEBEEFM2M Posted December 7, 2014 Author Report Posted December 7, 2014 So just get a new cable basket and clutches and eliminate all that shit from being a possibility? Quote
sprinklerman Posted December 7, 2014 Report Posted December 7, 2014 I'd find out what is actually causing it. That was just a list if possibilities. Quote
locogato11283 Posted December 7, 2014 Report Posted December 7, 2014 It's probably just out of adjustment. Quote
