Used an impact with crank in some sort of cushy vice? Maybe a touch of heat is needed. Use a little map gas tank and warm it up, tap on the sides with a big flat head, then a socket that is to small and tap on it a few times, then hit it with the impact.
hmm i bet the gear is supposed to just slide off. must have got a bit of corrosion going on. anyways something like this will get it off in a jiffy. the tools aint worth buying for a one time use but maybe a local mechanic shop will do the job for a couple dollars https://images.search.yahoo.com/images/view;_ylt=AwrTcXjzrXZU8W4AYi2JzbkF;_ylu=X3oDMTIzMGg2bGFkBHNlYwNzcgRzbGsDaW1nBG9pZAM4YjRkYjNkMmI4NDUyMzM5ODRiMDJiMGQyNDg1Y2VmOARncG9zAzU3BGl0A2Jpbmc-?.origin=&back=https%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3F_adv_prop%3Dimage%26va%3Dbearing%2Bseparator%2Bwith%2Bpuller%2Battached%26fr%3Dslv1-tyc8%26tab%3Dorganic%26ri%3D57&w=410&h=500&imgurl=www.benzworld.org%2Fforums%2Fattachments%2Fw123-e-ce-d-cd-td%2F502819d1363662093t-selection-pullers-rear-wheel-bearings-hubs-bearing-separator-3.jpg&rurl=http%3A%2F%2Fwww.benzworld.org%2Fforums%2Fw123-e-ce-d-cd-td%2F1702795-selection-pullers-rear-wheel-bearings-hubs.html&size=20.6KB&name=...+of+pullers+for+rear+wheel+bearings+and+hubs-bearing<%2Fb>-separator<%2Fb>-3.jpg&p=bearing+separator+with+puller+attached&oid=8b4db3d2b845233984b02b0d2485cef8&fr2=&fr=slv1-tyc8&tt=...+of+pullers+for+rear+wheel+bearings+and+hubs-bearing<%2Fb>-separator<%2Fb>-3.jpg&b=0∋=96&no=57&ts=&tab=organic&sigr=1390m9ntk&sigb=146sqqggd&sigi=14cetk6sr&sigt=12lqp6oeb&sign=12lqp6oeb&.crumb=l8ocyLj6iNd&fr=slv1-tyc8
Edited by registered user
Yep, the primary can be a pain. Especially if it's got RTV on the keyway. Worst case, you have to fashion a puller. Shouldn't be to bad. Definitely resist the temptation of prying against the case. I've seen guys try to use claw hammers and mat the clutch cover sealing surface and break teeth off the gear.
Registered posted a pretty swank set up to use. I bet you can use one from the auto parts store for cheap. You might as well even buy one knowing it could be a tool you need in the future as well.
Edited by trickedcarbine
