Hotrods crank o rings?
theputz
^ not sure if that's legit? But things go bang on the other side of the piston, so not entirely needed if you use sealant or LOCTITE on the outer race so it won't spin.
OP, why do you think they won't fit? They come with them correct? They are rubber and stretch. Just picture in your head how you can walk it over the journals and in between the journals so it can stretch up around the rod. It's fine. I'd imagine little Asian ladies in the factory are putting them on in a matter of seconds.
