tyler73 Posted October 19, 2014 Author Report Posted October 19, 2014 the mechanic said to change the choke plunger first then go from there Quote
fastbanshee8 Posted October 20, 2014 Report Posted October 20, 2014 Go buy yourself a Clymer's manual, and do some reading. 1 Quote
tyler73 Posted October 20, 2014 Author Report Posted October 20, 2014 Ok I will yeah I just don't see why it could be jets it idles really good when it's warm and runs fine no matter what temp it is all I know is it has a hard time idling when it's cold for more then 10sec Quote
trickedcarbine Posted October 20, 2014 Report Posted October 20, 2014 Definitely remove the carb to do any work. Keeps from getting junk in them and also keeps you sane actually being able to work on it with out being all hunched over trying to figure something out for the first time. Also put a new piece of vacuum tube between the two carbs as well. Quote
tyler73 Posted October 27, 2014 Author Report Posted October 27, 2014 It is fixed it was a bad choke and carbs had a lot of sand in them Quote
9498banshee Posted October 27, 2014 Report Posted October 27, 2014 i have to shake mine for it to start and idle when its cold out side, or if it has been awhile since its been running Quote
oldskool Posted October 28, 2014 Report Posted October 28, 2014 i have to shake mine for it to start and idle when its cold out side, or if it has been awhile since its been running If you are serious, Think a good carb cleaning should be in your near future Quote
9498banshee Posted October 28, 2014 Report Posted October 28, 2014 Yes but it has always been that way Atleast the last 8 years anyhow Quote
9498banshee Posted October 28, 2014 Report Posted October 28, 2014 I have a 25 pilot. When I went to a 27.5 I ate plugs all the time Quote
ETR174 Posted October 28, 2014 Report Posted October 28, 2014 That's what the choke is for. It allows an extra circuit of gas to be let through causing a rich condition to start. Quote
