fbt551 Posted October 1, 2014 Report Posted October 1, 2014 transfers have 120*duration Exhaust is 180*durarion I dont have pictures right now but intakes have boysen ports Quote
trickedcarbine Posted October 1, 2014 Report Posted October 1, 2014 Sounds like some one just tossed a 7mm crank in a set up for much less stroke. You may have a lemon on your hands. Quote
BANSHEE HP Posted October 1, 2014 Report Posted October 1, 2014 More stroke. If the port timing are that low with a 7mm crank they'd be higher on cylinder ported for a 4mm. Quote
BANSHEE HP Posted October 1, 2014 Report Posted October 1, 2014 180° is like 34.5mm exhaust on a 7mm 197° is 30mm on a 7mm Quote
BANSHEE HP Posted October 1, 2014 Report Posted October 1, 2014 30mm on a 4mm is 191° 34.5 on a 4mm is 172° Quote
sleeper06 Posted October 1, 2014 Report Posted October 1, 2014 Sounds to me like someone decked those cylinders down to get those numbers better degree that again and check it Quote
fbt551 Posted October 1, 2014 Author Report Posted October 1, 2014 Ill go back out there and check they were ported by an active sponsor Quote
fbt551 Posted October 1, 2014 Author Report Posted October 1, 2014 30mm on a 4mm is 191° 34.5 on a 4mm is 172° Rechecked its 190/130 I believe its more of a dune port Quote
sleeper06 Posted October 1, 2014 Report Posted October 1, 2014 That's why I said check it numbers didn't make sense to me , those cylinders have to little blow down for my liking but will have smooth power delivery enjoy, every ones definition of dune port is diffrent to me it's more aggressive trail hill shooter style porting Quote
fbt551 Posted October 1, 2014 Author Report Posted October 1, 2014 Im looking for straight drag with some hill shooting I was running 203/134 on my 350 on light frame and im light also was thinking of going 205/138 Quote
fbt551 Posted October 1, 2014 Author Report Posted October 1, 2014 7mm longrod 39mm carbs out frame pipes hopefully shearers Quote
sleeper06 Posted October 1, 2014 Report Posted October 1, 2014 200/130 is perfect for that motor don't go any higher 1 Quote
