New Pistons Bc compression dropped on right side .. Took head off and piston ring was shot to shitt , so figured Id replace Pistons along with rings as well
Starts on first kick no problems no over heat , put 340 main 30 pilot with the needles that I ordered from vitos 2 clip from bottom .. It spits a little oil out of the over flow hose after she warms up a little .. Any suggestions ?
I see where you said your guy done a leak down test. So I have a question. You say it's over revving, is the idle staying up for a few seconds after you rev it up? If it is, that's a hang idle and a sign of an air leak. I would leak down again just to be safe.
That provlem was all solved after rejet .. Only problem Im having is over flow hose oil is coming out .. Draining and refilling with 1.5 oil
You can over jet to compensate for an air leak.
Exactly why I said to take it to sleeper06. Guy has the tools and knowledge to get your bike perfect.
