biglaaa
Everything posted by biglaaa
  1. biglaaa
    Nerf bars
    I am lookin for a set of nerf bars prefer polished aluminum or black .. New used doesn't matter , just fairly good condition and hardware included .. I have 2 polished aluminum front rims ( stock) for trade possibly ! Thanks guys
  2. Interested in the lights but can't send a message for some reason ..
  3. Thank you everyone !
  4. What's a good brand ? Can't really find any polished or chrome ones on eBay or here
  5. Check your messages
  6. Prefer oem since my brake side and throttle are polished , lookin for oem polished lever and perch , or as close to it as possible , minus the parking brake(since its been detached from the bike )
  7. biglaaa
    f/r fenders !
    Just messaged u
  8. Gotchya thank you appreciate it !!
  9. How much leaner should I go for the winter ?
  10. What should I jet for then ? I jetted where she is a little rich considering it's still 60s in NYC ..
  11. Thank you man !! Thank you to everyone for the help
  12. I'm saying my mechanic friend blew a piston ring .. So I replaced them
  13. When I get a chance to get the bike down to him i def will .. Already spoke with him about that . What is the best oil to use for a banshee ?
  14. That provlem was all solved after rejet .. Only problem Im having is over flow hose oil is coming out .. Draining and refilling with 1.5 oil
  15. Also jetted Rich since temp here is 65-70 and I'm jetting so I can last the winter , which will drop to 20s for winter New York city
  16. It was running real lean over revving very heavy with 320s 30 and 2nd from bottom so I went to 340 ..
  17. Did not do a plug chop . She runs though perfect through gears .. Should I put clip in the middle ?
  18. Yea changed them Rejetted ! Never ran better in my life since I had it haha
  19. biglaaa
    f/r fenders !
    in need of some black or dark grey front and rear fenders in nyc area will pay shipping to zip 11219 thanks in advanced !
  20. 1) What type of aftermarket exhaust do you have? pc 304s 2) What type of air filter do you have? k&n 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all B . 4) What is your elevation? (If you don't know, go here: http://www.topozone.com ) sea level 5) What size pilot jets are you using?30 6) What size main jets are you using?340 7) What temperature is your Banshee jetted for? 20-60 8) Do you have a port job? bored 0ver with 65mm vitos super stock 9) What kind of carbs? stock 10) What size carbs? stock
  21. What does a banshee take ? How much oil ?
  22. Vitos performance
  23. I believe it's just too muh oil .. Should I drain and change ?cor let it run out ? Asking because not sure what to do
  24. Starts on first kick no problems no over heat , put 340 main 30 pilot with the needles that I ordered from vitos 2 clip from bottom .. It spits a little oil out of the over flow hose after she warms up a little .. Any suggestions ?
  25. New Pistons Bc compression dropped on right side .. Took head off and piston ring was shot to shitt , so figured Id replace Pistons along with rings as well
