I built my motor two years ago and have been very happy with it. After two years I want a little more... My buddy has built up is YFZ and now I need to step it up. Here is what I got so far:
421 Serval
Noss head with FAST 24CC domes
35MM Kehin Carbs (160 mains, 48 pilots, CEL needle in middle clip)
VForce 4
UPP Intakes with stock crossover tube
Snipe Pipes
FAST Clutch
Mattoon Timing plate @ +4
94 Octane gas with Klotz R50
Would I benefit from smaller domes, race gas, porting and 39 mm carbs? What kind of gains would I expect?
I'm with Twinklerman.. You're missing out on about 15HP.
Carbs - $350
Porting - $200??
Domes - $100
Right now the best bang for your buck is to do these three things. The rest of your setup is solid.
I was running the same exact set up as yours last year, but with Shearers.  I had mine ported over the winter by Redline and new domes cut. I'm very happy with it and was well worth the money. It pulls harder and doesn't drop off as fast as a cast serval. I'm still on pump gas too.
I don't see many running 39mm carbs or race gas. Are any of you?
39s rock on a Serval. If you can afford 100LL or racegas, you can go a little more aggressive on the porting and still keep (or gain) bottom and midrange.
