Messed up, need help
TroyBrock
Hey guys, quick background before I get to the problem. I recently fixed the idle gear and put in a new clutch, did everything to specs, used 3 HD and 3 regular springs and it was adjusted right. First few days it was great, then I noticed it was starting to be alittle jerky when I shifted from neutral to first, then it got real bad so I decided to take off the clutch over.
Now here's the problem, 2 broken inner hub bolt holes and 2 other spring screws had started to back out. And the idle gear once again lost it's clip. I have a new inner basket and idle gear ready to go. I know the springs are suppose to be tighten to 7 lb/ft but I'm wondering what I can do to make sure this doesn't happen again. And if anyone might have and insight into what happened the first time.
Thanks
Troy
banshee hub appears to be the same essential design as every other 2t engine on the planet. ive never had a problem with them bolts going loose with 7ftlbs and no loctite on other engines. the problem with doing them hand tight is most people cant gauge torq very well by hand and thats how them bolts get stripped out.
Edited by registered user
