Nash Jesso Posted August 14, 2014 Report Posted August 14, 2014 So today i went out to start my shee it fired up but idled high.shut it down and waited a bit,went back and it fired up and idled fine then died.i tried kicking it over again and it just smoked out of one exhaust pipe and wouldn't start.can somebody help me with this?! Quote
Surfrjag Posted August 14, 2014 Report Posted August 14, 2014 Check fuel, clean carbs, new plugs, check spark. Try again Quote
trickedcarbine Posted August 14, 2014 Report Posted August 14, 2014 Check all the stupid simple stuff, but you may have an air leak Quote
Nash Jesso Posted August 14, 2014 Author Report Posted August 14, 2014 Well started it about 10 minutes after and it fired up and ran perfect idled perfect and seemed normal,could it be my carb is dirty and one slide may be sticking? Or maybe carbs not synced? Quote
Sandking Posted August 14, 2014 Report Posted August 14, 2014 Plugged pilot jet cleared itself out and good to go. Put a filter on the fuel line and don't leave old fuel in there. Quote
Nash Jesso Posted August 15, 2014 Author Report Posted August 15, 2014 Yeah im getting one of my buddies to drop over tomorrow and clean tge carbs and get them synced,also gunna swap out plugs,when i got it the bike had br9es plugs but im almost certain it supposed to be br8es plugs in there. Quote
Nash Jesso Posted August 19, 2014 Author Report Posted August 19, 2014 Figured out the problem,both pilots were plugged and the left carb was missing an air screw.cleaned the pilots and 2 new airscrews are ordered,thanks guy's! Quote
