CottonBranchRacing Posted August 19, 2014 Report Share Posted August 19, 2014 Anywhere between 100 and 200 on eBay, I have a stock trans, drum, and forks you can have for 150 plus freight Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 19, 2014 Report Share Posted August 19, 2014 If it weren't for one of the teeth being wedged in the gears I probably would have never know it happened. What should a set of gears cost? You can buy complete transmissions from $100-125. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 19, 2014 Report Share Posted August 19, 2014 HAha Quote Link to comment Share on other sites More sharing options...
landonwood20 Posted August 19, 2014 Author Report Share Posted August 19, 2014 Are the gears the same for every year? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 19, 2014 Report Share Posted August 19, 2014 Are the gears the same for every year?Like are they all the same size? Quote Link to comment Share on other sites More sharing options...
landonwood20 Posted August 19, 2014 Author Report Share Posted August 19, 2014 Yes, so I can buy any year and they will all fit Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 19, 2014 Report Share Posted August 19, 2014 (edited) Ya Komisar Motorsports if you don't work out a deal on here. Edited August 19, 2014 by trickedcarbine Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 19, 2014 Report Share Posted August 19, 2014 Yup. 87-12. Do your self a favor and spend a few bucks - modded trans - new shift forks - new shift shaft - new eccentric screw - new cable - new pressure plate, hub, basket and clutch (if old one is all stock or worn) - new locking tab for eccentric bolt and basket bolt That's all I'm thinking off the top of my head. There might be more. Quote Link to comment Share on other sites More sharing options...
landonwood20 Posted August 19, 2014 Author Report Share Posted August 19, 2014 Awesome, make buying them 10x easier thanks for the help. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 19, 2014 Report Share Posted August 19, 2014 Yup. 87-12. Do your self a favor and spend a few bucks - modded trans - new shift forks - new shift shaft - new eccentric screw - new cable - new pressure plate, hub, basket and clutch (if old one is all stock or worn) - new locking tab for eccentric bolt and basket bolt That's all I'm thinking off the top of my head. There might be more. Very large investment, however the return is huge. A reliable smooth operatin machine that if maintained, will last a good while Quote Link to comment Share on other sites More sharing options...
